#1 |
Localización: Madrid
Buenas,me gustaria saber vuestra opinión de este monitor de 22",voy a jubilar mi CRT ya que me esta empezando a hacer cosas raras,el monitor lo puedo conseguir por un precio bastante mas bajo del normal,pero solo este,las caracteristicas son las siguientes:
![]() * Large diagonal viewable area display * 1680 x 1050 factory-set resolution * Video inputs supported: o VGA analog signal o DVI-D digital signal * Fast response time provides better experience for gaming and graphics. * Plug and Play capability, if supported by your computer system * On-screen display (OSD) adjustments for ease of setup and screen optimization * Energy Saver to reduce power consumption Technical specifications LCD feature Specification Display size 22-inch (55.8 cm) diagonal and viewable image Display type TFT liquid crystal Input terminal 1 VGA 15-pin D-type connector (analog cable included) DVI-D connector (DVI cable not included) Scanning frequency Horizontal scan range 24-94 KHz Vertical scan range 48-75 Hz Recommended resolution (H x V) 1680 x 1050 @ 60 Power source - AC/DC adapter Input rating: 100 to 240V~ Frequency: 47-63 Hz Power consumption: <55 W in operating mode, <2 W in sleep mode Operating environment Temperature: 41 degrees F to 104 degrees F (5 degrees C to 40 degrees C ) Humidity: 20% RH through 85% RH (non-condensing) Storage environment Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C) Dimensions H x W x D, including base: Including base: 17.1 x 20.7 x 9.8 inches (43.4 x 52.5 x 24.8 cm) Weight Unpacked: 15.43lbs (7.0 Kg) EMI standard FCC Class B EPA Energy Star As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency. http://h10025.www1.hp.com/ewfrf/wc/d...name=c00772014 A pesar de tener 5ms,no lo usaré para juegos de PC,excepto en alguna ocasión que por necesidad tenga que poner la 360 en este monitor. Saludos. |
#2 | |
![]() Fecha de Ingreso: may 2006
Cita:
Saludos. |
#3 |
Me lo dejan por 150€,la idea es sustituir mi CRT actual,no voy a ver peliculas en el ni nada de eso,simplemente navegar y tal y en alguna ocasión la x360(cuando no pueda usar la bravia de 40"),pero poco mas,es buena compra?
#4 |
Que si es buena compra???, yo creo que puedes comprarte una docena y venderlos en ebay por 300€ sin problemas jeje. Por ese precio está estupendamente.
Saludos. |
#5 |
Genial entonces,gracias por el consejo,por cierto,que precio tiene este monitor en tiendas,se que es bajo porque otra de las ofertas es un equipo HP valorado en 1700€(segun corte ingles claro) me sale por 600€,pero no lo encuentro en alternate.
#6 | |
Cita:
Saludos. |
#7 |
Edad: 34
Por 150 pegame un toque y me pillo otro, joer, es un chollo, la gente se centra demasiado en pequeños detalles.
#8 |
Es una oferta especial de empresa,ya me pille la Sony bravia V 40" por 1200€(3500€ creo que costaba cuando la pille),ahora vuelve a salir una oferta parecida y por eso me lo pillo,es un catálogo muy limitado,pero tienen buenas cosas.
#9 |
¿donde se puede comprar en España?
La verdad es que como monitor TN no tiene mala pinta
__________________
Última edición por Sr_lobo fecha: 17/10/06 a las 09:36:47 |
#10 |
Ni idea,como ya dije,lo pillo por empresa,es decir,a mi padre y a mi hermano en sus respectivas empresas cada año sacan "un catalogo" pequeño con varias ofertas de productos MUY rebajados porque teoricamente son para apredizaje o algo asi(tecnicismos raros),realmente no pagas en el momento,sino que te lo van quitando del sueldo,la Bravia la pillamos por mi hermano y ahora han hecho lo mismo en la de mi padre(no voy a decir nombres porque son muy conocidas xD)y le dije que pillase el monitor,que el mio se estaba muriendo ya.
Sobre precios aqui en España,estuve buscando pero nada de nada,ni en alternate ,ni en el corteingles online,miré aqui porque es el típico monitor que aparece en el corteingles pero nada,quiza en izarmicro este. |
| Herramientas de Tema | |
| Modos de Visualización | |
