Página 1 de 28 1234511 ... ÚltimoÚltimo
Resultados 1 al 10 de 273
Tema: [Review] ASUS VG278H 27" LED 3D
    Master
    Murcia
    Predeterminado [Review] ASUS VG278H 27" LED 3D
    Hoy os presento este estupendo monitor ASUS VG278H 27" LED 3D .
    Datos técnicos :
    Display Panel Size: Wide Screen 27.0"(68.6cm) 16:9
    True Resolution : 1920x1080
    Full HD 1080P : Yes
    Pixel Pitch : 0.311mm
    Brightness(Max) : 300 cd/㎡
    ASUS Smart Contrast Ratio (ASCR) : 50000000:1
    Viewing Angle (CR≧10) : 170°(H)/160°(V)
    Response Time : 2ms (Gray to Gray)
    Display Colors : 16.7M
    Video Feature Trace Free Technology
    SPLENDID Video Intelligence Technology
    SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
    Skin-Tone Selection : 3 Modes
    Color Temperature Selection : 4 Modes
    HDCP support
    Audio Features Stereo Speakers : 3W x 2 Stereo RMS
    Convenient Hotkey SPLENDID Video Preset Mode Selection
    Auto. Adjustment
    Brightness Adjustment
    Contrast Adjustment
    Input Selection
    I/O Ports Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
    PC Audio Input : 3.5mm Mini-Jack
    AV Audio Input : HDMI 1.4
    Audio Output : HDMI 1.4
    Earphone jack : 3.5mm Mini-Jack
    Signal Frequency Analog Signal Frequency : 24~140 KHz(H)/ 50~122 Hz(V)
    Digital Signal Frequency : 24~83 KHz(H)/ 50~85 Hz(V)
    Power Consumption Power On< 65W
    Power Saving Mode< 1W
    Power Off Mode< 1W
    Mechanical Design Chassis Colors : Black
    Tilt : +15°~-5°
    Swivel : Yes
    Height Adjustment : Yes
    VESA Wall Mounting : 100x100mm
    Security Kensington lock
    Dimensions Phys.Dimension(WxHxD): 643x460x220mm
    Box Dimension(WxHxD): 732x560x176mm
    Weight Net Weight (Esti.): 8 kg
    Gross Weight (Esti.): 10 kg
    Accessories Dual-link DVI cable
    VGA cable
    Audio cable
    Power cord
    Quick start guide
    Warranty Card
    Nvidia 3D Vision Kit
    Regulation Approval Energy Star®, ErP, UL/cUL, CB, CE, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, J-MOSS, PSB, RoHS, WEEE, Windows 7 WHQL
    El nuevo monitor dispone de las tecnologías NVIDIA® 3D Vision™ 2, 3D LightBoost™, una frecuencia de refresco de 120Hz y una pantalla 3D con un diseño ergonómico
    ASUS ha presentado el VG278H, un monitor 3D de 27” que cuenta con 120Hz de refresco, un tiempo de respuesta de 2ms, soporte para las nuevas gafas NVIDIA® 3D Vision™ 2 y la tecnología NVIDIA® 3D LightBoost™, la cual mejora el entorno 3D con unas imágenes 3D el doble de brillantes y con un color más preciso que las tecnologías anteriores. El VG278H también incorpora un diseño ergonómico que permite regular la altura, inclinación y el ángulo del panel, así como un emisor 3D Vision regulable que permite disfrutar de la mejor visualización posible desde la posición preferida por el usuario.
    Una experiencia 3D sin concesiones
    El monitor ASUS VG278H cuenta con las nuevas tecnologías de NVIDIA® 3D Vision™: 3D LightBoost multiplica por dos el brillo de las imágenes 3D sin incrementar por ello el consumo energético, y el nuevo diseño de las gafas 3D Vision, que cuenta con unas lentes con una visibilidad incrementada un 20%, un visor que bloquea la luz externa y un diseño inspirado en la estética gamer. El VG278H permite disfrutar en 3D de un amplio rango de contenidos como video en streaming desde internet, películas Blu-ray y más de 550 juegos. El emisor 3D Vision integrado puede direccionarse directamente a las gafas para una recepción óptima de la señal y los tres modos de infrarrojos 3D (Normal / CE Compatible / LAN party) permiten evitar posibles interferencias derivadas del entorno en el que sean empleadas.
    Acción fluida y sin fisuras
    La tecnología Trace-Free II combina la frecuencia de refresco de 120Hz y los 2ms de respuesta para doblar las imágenes por segundo reproducidas, lo que resulta en una imagen fluida y sin fisuras. El VG278H también incluye la tecnología Advanced Dual-side LCD Driving, que reduce el tiempo de carga del panel LCD, previniendo el efecto ghosting, las líneas brillantes y asegurando la imagen 3D más nítida para todo tipo de contenidos.
    Adecuado para cualquier escenario de uso
    Los ingenieros de ASUS han optimizado el VG278H para ofrecer la respuesta en color más adecuada para los ajustes Gamma de Photoshop en los seis modos disponibles: cine, escenas nocturnas, paisaje, gaming, sRGB y estándar. La peana permite regular la altura, inclinación y el ángulo del panel para proporcionar la visualización más cómoda para el usuario. A nivel de conectividad, el VG278H incluye puertos DVI-D, D-sub y HDMI 1.4 para la conexión de dispositivos Blu-ray.
    Unboxing :
    Bueno a primera vista conforme vamos desempaquetando podemos ver el gran tamaño de la caja :
    Dentro podemos aprecia a primera vista el kit de Nvidia 3D vision ™ 2 que luego compararemos con la version anterior :
    Empezamos por a sacar los accesorios que consta de :
    Pack Nvidia 3D vision™ 2
    Cable de alimentacion
    Cable DVI
    Cable RGB
    Manuales Drivers etc...
    Unas fotos del monitor en todos sus ángulos :
    Primeras conclusiones :
    a primera vista la gama de colores debido al estupendo ratio de contraste que trae este Asus 50000000:1 hace que los colores se vean de autentico lujo , luego la iluminación LED también hace que sea muy bueno en lo que a brillo se refiere .
    En el 3D es donde hay una gran diferencia con sus predecesores ya que la implementación del Lightboost en 3D contrarresta cualquier oscuridad que pueda verse con las imágenes en 3D. Con esta tecnología produce casi dos veces más de brillo que los convencionales de monitores en 3D. No sólo para 3D, también produce imágenes excepcionalmente claras y vívidas en 2D.
    Una experiencia de inmersión en 3D con NVIDIA 3D LightBoost Technology
    Con la última tecnología NVIDIA 3D LightBoost Technology, disfrutar el doble de brillo de la tecnología convencional de 3D ​​en el modo 3D con cero aumento en el consumo total de energía. Es perfecto para los juegos de color oscuro, como Metro 2033 y Batman: Arkham City. Además, las gafas de nuevo diseño viene con NVIDIA 3D LightBoost Technology cuenta con un lente de visión de 20 por ciento más grande, un visor de bloqueo de la luz para una visualización cómoda y confortable - jugador de inspiración del diseño.
    una foto tomada por mi para que veáis la diferencia entre las dos gafas :
    y otra de las monturas lo que mas me gusta , son super ligeras :
    Ultra-smooth Action 120Hz
    Doble velocidad de 120Hz frecuencia de actualización con tiempo de respuesta de 2 ms
    Con el apoyo de la tecnología Trace Free II, el VG278H es capaz de duplicar la velocidad de refresco a 120 fotogramas por segundo, que es dos veces más rápido que el genérico de los monitores LCD, ofreciendo ultra-suaves efectos visuales en 3D. Por otra parte, el tiempo de respuesta se ha reducido a 2 ms para eliminar el seguimiento y garantizar la reproducción de imágenes claras y precisas
    Con respecto al ghosting/crosstalk solo puedo decir que no se elimina totalmente aunque nada que ver con mi LGW2363D, aunque he probado la formula de bajar el contraste y la verdad es que desaparece casi por completo , ver aquí More on Ghosting and Brightness of the Asus VG278H 3D Monitor - 3D Vision Blog .
    La conclusión final es que estamos ante el mejor monitor para 3D , la única pega es su alto precio
    Última edición por pakitoesp; 14/11/2011 a las 08:00
    • CPU y GPU : I7 5960x @ 4.5 Ghz /1,20v + GTX 980 TI .
    • Memorias : Gskill DDR4 3000 Mhz @ 3125Mhz / x3 SSD 500GB Crucial .
    • Placa base : Rampage V + Corsair AX 1200i .
    • Caja : Little Devil PC-V8 +RL Custom para CPU y GPU .
    • Sonido : Asus STX II
    • Monitor : Philips BDM4065UC 4K
    Predeterminado Re: [Review] ASUS VG278H 27" LED 3D
    Cuando escribes Nvidia 3d Vision 2 glasses debes poner una coma entre el 2 y glasses que sino da confusión. Este monitor lo tengo el ojo desde hace mucho.
    Disfrutalo por mi. Un saludo.
    i7 3930K XSPC RAYSTORM ASUS R4E GTX590 (EK FC590) + GTX580
    ASUS VG278H HAF-X CRUCIAL M4 128Gb
    El señor de los forillos Avatar de corderazo
    Moratalaz
    Buena review,disfruta de ese pedazo monitor.
    Gracias ¿Cual es su precio?
    Sobremesa: Intel i2600k-Asrock Z68 Extreme 4/SSD Vertex 2
    8 Mb RAM 1600 G.Skill Ripjaws -
    Thermalright Archon
    Portátil: Asus A53S-- i7 2670QM 8Gb.
    TV Samsung 87M40 y 32D6000 - Zidoo X9S-PS4 Slim 250 Gb.
    Mi Blog
    Guía para ver Matroska con/sin DVXA - Efecto Judder
    Popcorn Hour A-110
    PS3 Slim - 250 Gb.
    Pedazo de review y menuda adquisicion que te has "marcado".
    A disfrutarlo muchisimo y salu2.
    Master
    Murcia
    Cita Iniciado por defensivepepe Ver mensaje
    Corregido , gracias por el apunte .
    Cita Iniciado por corderazo Ver mensaje
    Gracias tio , un saludo.
    Cita Iniciado por JC&J&MC Ver mensaje
    545€ ,saludos .
    Cita Iniciado por dagosal Ver mensaje
    Gracias dagosal,saludos.
    Master
    Murcia
    Haber si tengo tiempo y hago una comparativa entre este ASUS el LG para que veais las diferencias que son bastantes ,saludos.
    Cita Iniciado por pakitoesp Ver mensaje
    espero esa comparativa tanto en 2d como en 3d, muchas gracias pakitoesp
    Master
    Murcia
    Cita Iniciado por leomen Ver mensaje
    Si haber si cojo tiempo y la hago ultimamente no es que este muy sobrado de el ,saludos.
    Osea, para 3D es el mejor que hay, y no se sabe de ninguno que vaya a salir este mes o el que viene que lo supere no?
    Conclusión: cae pa reyes xD
