Cita:
Hi all,
It looks like I've just fixed the problem.....thanks to my I.T. Guru (Tony)
Step 1, download windows 10 using the link + instructions above.
Step 2, boot laptop/PC using USB stick
Step 3, let stick boot up and follow instructions until you see repair windows install, go through options and select command prompt.
Step 4, When you are at the command prompt run these options :-
Bootrec /fixMBR
bootrec /fixBoot
bootrec /rebuildBCD
once done type exit.
Step 5, reboot as normal ......... and hopefully you'll be back in windows 10 with no lost of data.
Step 6, Enjoy ........ for how long, I don't know. That's Windows for you I guess.
Microsoft take note.......NOT HAPPY :(
