Quien tenga instalado la version final filtrada del edge nuevo,al darle a acerca de edge me ha saltado una actu y se me ha actualizado.
Versión para imprimir
Nueva acumuklativa KB4512941 (OS Build 18362.329)
Y si...Sandbox ya funciona.
Improvements and fixes
This non-security update includes quality improvements. Key changes include:
Addresses an issue that displays a black screen when you use Remote Desktop to connect to a machine running Windows 10, version 1903.
Addresses an issue that may prevent the Windows Sandbox from starting with the error, "ERROR_FILE_NOT_FOUND (0x80070002)." This occurs on devices in which the operating system language is changed during the update process when installing Windows 10, version 1903.
Increases the number of supported interrupts per device to 512 on systems that have x2APIC enabled.
Addresses an issue that prevents some Trusted Platform Module (TPM) devices from being used for Next Generation Credentials.
Addresses an issue that causes a workstation to stop working when you sign in using an updated user principal name (UPN) (for example, changing UserN@contoso.com to User.Name@contoso.com).
Addresses an issue that prevents Windows Defender Advanced Threat Protection (ATP) from running automated forensic data collection when using registry-based proxy configuration.
Addresses an issue that prevents Windows Defender Advanced Threat Protection (ATP) from sending cyberspace events for paths beginning with \\tsclient.
Addresses a possible compatibility issue when Windows Defender Advanced Threat Protection (ATP) accesses case-sensitive Server Message Block (SMB) shares.
Addresses a rare issue that occurs when the mssecflt.sys driver takes too much space on the kernel stack. This results in the error, "STOP 0x7F: UNEXPECTED_KERNEL_MODE_TRAP", and Parameter 1 is set to “EXCEPTION_DOUBLE_FAULT.”
Addresses an issue that leads to excessive memory utilization in Windows Defender Advanced Threat Protection (ATP).
Improves the detection accuracy of Microsoft Defender ATP Threat & Vulnerability Management.
Addresses an issue in which Windows Defender Application Control will not allow third-party binaries to be loaded from a Universal Windows Platform application. CodeIntegrity event error 3033 appears as, “Code Integrity determined that a process (<process name>) attempted to load <binary name> that did not meet the Store signing level requirements.”
Addresses an issue that causes devices to have truncated device names when Autopilot provisioning automatically assigns a name to them.
Addresses an issue in which the product description of Windows Server 2019 was incorrect when queried using slmgr /dlv.
Addresses an issue that causes the Windows Management Instrumentation (WMI) class Win32_PhysicalMemory to report that 32 GB memory chips have a missing Capacity value.
Addresses an issue that prevents you from copying and pasting compound documents (formerly OLE objects) between an application that hosts the RichEdit control and other applications.
Addresses an issue that prevents certain games from leveraging Spatial Audio capabilities.
Addresses an issue that fails to provide a cursor when you select a text input element using touch.
Addresses an issue that may cause the name of an unsupported application to appear as default text, such as “ms-resource:AppName/Text” in the Start menu after upgrading the operating system.
Addresses an issue that may prevent the personal identification number (PIN) prompt from appearing when authenticating in Internet Explorer.
Addresses an issue with downloading digital rights management (DRM) files from certain websites using Microsoft Edge and Internet Explorer.
Improves the user experience and app compatibility so that more Win32 apps will work with Windows Mixed Reality.
Addresses an issue with LdapPermissiveModify requests, which fail to make Active Directory (AD) group membership changes if the Lightweight Directory Access Protocol (LDAP) client uses the Security Identifier (SID) syntax. In this scenario, Active Directory returns a “SUCCESS” status even though the change did not occur.
Addresses an issue that may prevent devices from starting when they start up using Preboot Execution Environment (PXE) images from Windows Deployment Services (WDS) or System Center Configuration Manager (SCCM). The error is, "Status: 0xc0000001, Info: A required device isn't connected or can't be accessed."
Addresses an issue that may prevent devices from starting up or cause them to continue restarting if they are connected to a domain that is configured to use MIT Kerberos realms. Domain controllers and domain members are both affected.
Addresses an issue that may cause the following to stop responding:
Applications that were made using Visual Basic 6 (VB6).
Macros that use Visual Basic for Applications (VBA).
Scripts or apps that use Visual Basic Scripting Edition (VBScript).
You may also receive an "Invalid procedure call” error.
If you installed earlier updates, only the new fixes contained in this package will be downloaded and installed on your device.
A ver si me ayudáis. No me funciona el Sandbox, me da este error:
https://i.imgur.com/5xayKkN.png
Parece como si no estuviese activado en la bios la virtualización. Se supone que he de activar la opción "Enable Intel Virtualization" y VT.
Me ha dado por buscar y no consigo encontrar la opción para activarla. Aquí sale como "supported" (SMX no):
https://i.imgur.com/ZEjnsri.png
La opción para activarla debería de estar un poco más abajo. donde "Execute Dissable Bit", pero sorprendentemente no sale:
https://i.imgur.com/k3V8Slc.png
La que si me sale, y en su sitio, es la de VT:
https://i.imgur.com/dv8FtyF.png
Empiezo a pensar que es que no lo tengo activado, pero me he tirado mucho tiempo en todas las opciones de la bios y no encuentro la de "Enable Intel Virtualization" que debería de estar donde indiqué en la segunda imagen. Es una placa de gama alta, una Asus X299 Deluxe, muy extraño todo .....
Yo acabo de actualizar a la versión 1903 desde la 1809 y me ha dejado de funcionar la barra de búsqueda, se me despliega como antes, pero se queda en negro (es como si no cargara). No sé si alguien le ha pasado lo mismo o alguien sabe alguna solución.
Pepillo vete al Admor de Tareas y bajo CPU comprueba si te pone Virtualizacion habilitada.
De todas formas abre las Caracteristicas de Windows y ahí encontrarás 1-2 opciones referentes a VT.
Prueba a activar las plataformas de Windows Hypervisor y Virtual Machine.
Obviamente Windows Sandbox que tb aparece ahí como opción debe estar activada.
Reinicia y prueba.
Un saludo
Para que usáis el sandbox?
Lo tengo habilitado desde hace unas semanas, pero salvo para probar alguna app antes o usarla sin instalar en el sistema no se me ocurre nada mas.
Me he auto-resuelto el problema después de ver que tocar registros, servicios, directivas, opciones de windows, reconstruir el index y demás, y ver que no se solucionaba el problema con la función de búsqueda y que estaba asociado a un uso grande de cpu por parte de Cortana continuamente (se me zampaba un 15% de cpu todo el rato). Por suerte llegué a este blog post:
https://borncity.com/win/2019/08/31/...-2019-updates/
que describen exactamente lo que me pasa a mí y es la última actualización de windows, la KB4512941 que han empezado a distribuir desde hace un par de días.
Lo gracioso es que insiders ya habían hablado de este problema (para mí la función de búsqueda es vital, la uso siempre desde que se integró en Win 8.1) y a MS parece que le ha dado igual. De nuevo, yo no sé para que tienen el programa Insider si MS no le hace caso a los usuarios.
En fín, si a alguien le pasa, ya sabéis lo que hay que desinstalar.
