Página 1 de 142 123451151101 ... ÚltimoÚltimo
Resultados 1 al 10 de 1419
Tema: [Hilo Oficial] - HD4770 / 4750 (HD4770 --> el 27-04-2009)
    Cuenta inhabilitada
    What does the scouter say about his power level?
    Predeterminado [Hilo Oficial] - HD4770 / 4750 (HD4770 --> 27-04-2009)
    Specs:
    RV740 - HD4770
    CoreClock --> 750Mhz
    ShaderClock --> 750Mhz
    Interfaz de memoria --> 128bit
    Frecuencia de memoria --> 800Mhz GDDR5, 3200Mhz efectivos
    Ancho de banda --> 51.2GB/s
    Stream Processors --> 640
    Texture Units --> 32
    ROPS --> 16
    Potencia teórica --> 960GFLOPS
    Número de transistores --> 826M
    Proceso de fabricación --> TSMC 40nm
    TDP --> 80w
    Otras tecnologías integradas --> UVD 2.0, AMD Stream
    Versión de DirectX --> 10.1
    http://www.newegg.com/Product/Produc...HD4770&x=0&y=0
    Precios newegg:
    $109 (modelo "genérico")
    Oh yes, acaba de salir mi precioso.
    Reviews:
    http://www.noticias3d.com/articulo.asp?idarticulo=1067
    http://translate.google.com/translat...1/1311308.html
    http://www.xbitlabs.com/articles/vid...on-hd4770.html
    http://news.ati-forum.de/index.php/t...-radeon-hd4770
    http://www.hexus.net/content/item.php?item=18202&page=6
    http://benchmarkreviews.com/index.ph...=295&Itemid=72
    http://www.elitebastards.com/cms/ind...=711&Itemid=27
    http://www.guru3d.com/article/ati-ra...d-4770-review/
    http://www.hardwarecanucks.com/forum...r5-review.html
    http://www.hartware.de/review_935.html
    http://hothardware.com/articles/ATI-...4770-40nm-GPU/
    http://www.legitreviews.com/article/963/1/
    http://www.motherboards.org/reviews/...re/1881_1.html
    http://www.neoseeker.com/Articles/Ha.../hd4770launch/
    http://www.pcstats.com/articleview.cfm?articleID=2392
    http://www.techpowerup.com/reviews/ATI/HD_4770/
    http://www.techspot.com/review/163-radeon-hd-4770/
    http://www.tweaktown.com/reviews/273...ard/index.html
    http://vr-zone.com/forums/424580/2-x...-gtx-285-.html
    Consumo del sistema en idle:
    Phenom II 810 2.6Ghz
    Kingston 2x1GB DDR3 1600
    MSI 790GX-G65 MSI 790GX-G65
    Seagate 7200.10 320GB
    Consumo del sistema en load:
    La gráfica pinta a ser dios bendito.
    Última edición por Nintendork; 28/04/2009 a las 20:48
    Predeterminado Re: [Hilo Oficial] - HD4770 / 4750 (HD4770 --> el 27-04-2009)
    Órale, eso de Dios bendito se oyó medio fanboy, pero nomás medio XD.
    En cuanto a rendimiento, se ve bien, según hasta más, en algunos casos, que una 4850, en otros se atora mucho, pero en general le saca un tramo decente a la 4830. Lo que insisto, me hubiera gustado, es que no necesitara conector extra, espero que alguna empresa le pula ese defecto pronto.
    Y para la review, un poquito más de juegos no habrían venido de más... De todas maneras espero más reviews, porque me interesa la tarjetita esta, considerando que ya me deshice mi 4670, la verdad hecho de menos el NF y poder usar los dos monitores.
    Equipo 1 - Core I7 930, 2.8 Ghz
    6 Gb DDR3.
    4x500 GB Barracuda Caviar
    Saphire 5450.
    Con domicilio en Noticias3d.com Avatar de Oliver91
    Terrassa
    El señor de los forillos Avatar de riper
    Valle Del Jerte
    Si que tiene muy buen rendimiento la 4770, es prácticamente como una 4850 pero con menos consumo (también un poquito menos potente, pero poco).
    Pues si se queda a buen precio en el mercado será una opción intersante para quien quiera jugar a todo decentemente sin gastarse mucho dinero y sin tener mucho consumo.
    -- Antec Three Hundred -- E8500@4Ghz (Tacen Gelus Pro 3) -- Asus P5Q-E -- 2x1Gb Crucial Ballistix 1066mhz + 2x1Gb Kingston HyperX 1066mhz -- Club3d HD4850 (Coolink GFXchilla)@(690/2326) -- Asus Xonar DS -- Logitech X-530 -- Maxtor SataII 250Gb -- 2x Maxtor Ide 80Gb -- Seagate SataII 500Gb 32mb -- Logitech MX518 -- LG FLATRON M237WDP FullHD -- Tacens Valeo Smart 560w --
    Tiene un consumo excelente...
    Pero entonces para qué necesita el conector externo de corriente ? A través de la placa base se pueden suministrar hasta 75W no ?
    Buena gráfica.
    Una de estas en pasiva quiero yo para mi HTPC. Me iba a comprar las HIS 4670 pasiva de 1 Gb, pero lo mismo me espero a esta.
    Tambien tengo la 4670 y me estaba planteando cambiar a esta 4770, pero lo del conector adicional no me acaba de convencer, segun el grafico solo consume dos watios mas que la 4670 y aun asi necesita de conector.
    El precio parece que va a ser muy competitivo, pero si hay que cambiar de fuente la cosa cambia.
    Si , ya se que lo queremos todo, buen rendimiento, poco consumo y menos calor, y un precio decente. Pero es que esta pintaba estar tan cerca de todo eso..
    P.D: ¿Alguna review habla del ruido? la que tengo ahora es una tumba, y me gustaria que la siguiente fuese igual.
    Cuenta inhabilitada
    Pero para qué pasiva, la 4670 GDDR4 ni se oye con el gigantesco venti que lleva.
    Si que revisan "poquísimos" juegos en xbitlabs xD.
    OC lulz con mod en rivatuner, catalyst no deja subir tanto.
    Eso habla de memos a 3600 capadas a 3200.
    This method allowed us to overclock Radeon HD 4770 to 860MHz GPU and 975 (3900) MHz memory frequency. The card remained stable at these frequencies and went through the entire test session without nay failures.
    *Extraña que ninguno haya recibido gráficas con la refrigeración para venta al público que a mi parecer se ve mejor.
    **En la prueba del crysis los de xb se loquearon con 4xAA, eso mata a todas las gráficas.
    No sé, pero me da que esta gráfica ha salido con ganas de destruir 4850's y 9800GTX+'s. He hecho bien en esperar...
    Última edición por Nintendork; 28/04/2009 a las 07:36
    Galicia
    AMD segun toms le sube el precio a 109 dolares con lo que segun ellos le quita parte de la gracia al invento.
    Estoy de acuerdo, pero ya bajará un poquillo..
    Galicia
    Confirmado en Newegg, unico sitio donde las he encontrado por ahora:
    http://www.newegg.com/Product/Produc...n=4770&x=0&y=0
