Página 1 de 54 123451151 ... ÚltimoÚltimo
Resultados 1 al 10 de 531
Tema: Samsung u28d590d
    Predeterminado Samsung u28d590d
    MONITOR 3840X2160P FECHA DE LANZAMIENTO 18/04/2014 PRECIO SUGERIDO U$S 700
    Precio y disponibilidad
    El Samsung U28D590D se pondrá a la venta en España a final del mes de mayo.
    El Samsung U28D590D nos ofrece una pantalla con una resolución UHD o lo que es lo mismo, de 3840×2160 píxeles a un precio de 599 euros. Para lograrlo el fabricante ha decidido hacer uso de un panel de 28 pulgadas tipo TN con un refresco de 60 Hz que se ve acompañado de dos entradas HDMI 1.4 y un conector DisplayPort 1.2.
    World best-in-class fast response time at 1ms!
    Your Samsung UHD monitor can handle all the excitement of action movies, games and sports easily thanks to a faster response time of 1-millisecond. You can see even the fastest on-screen motion clearly and smoothly without any motion blur, judder or ghosting. There's no lag during gaming, so it won't let you down at a crucial moment. All the details are right there before your eyes in astonishing UHD clarity and realism.
    Each and every colour richly detailed and truly brilliant
    Get richer and more vivid colours that were meant to be seen in 4K. Many monitors only offer you 16.7 million colours, but a Samsung UHD monitor gives you 64 times more - for an incredible 1 billion colours. That means everything you see is accurate, detailed, natural-looking and so vivid that it will take your breath away. There's also a smoother transition between different tones, passing through more shades in between. Let the UHD monitor show you everything that there is to be seen.
    Sharpen your content with UHD upscaling
    Bring out the best picture quality possible for all your favourite content and make them worthy of your UHD experience. Samsung's technology automatically detects the content's original resolution and improves it with noise reduction and up-conversion to create clearer, sharper images. Thanks to UHD upscaling, it brings all your entertainment and other content up to a new UHD-level.
    Multi-task and watch everything in its true glory
    The latest Picture-in-Picture 2.0 technology lets you multi-task and watch videos that maintain 100% of the source resolution. Whether it's 1080p ,720p or 480p, PIP 2.0 doesn't downscale contents and maintains the exact same resolution as clear and crisp on its own. It supports resolutions up to Full HD and you can adjust the PIP resolution and position to fit your needs. There's no loss in quality, so you can really have everything you want with no compromises.
    Use only one UHD monitor to see 2 different contents
    This advanced multitasking technology lets you do things you could never do before. With Picture-by-Picture, you can connect two PCs to the same monitor and see the desktops of both simultaneously on one screen that's divided into two. Thanks to PBP and the UHD resolution size you won't have to worry about losing any of the glorious picture quality and resolution. Plug in your laptop and your desktop and use both easily without needing to keep looking between different monitors - it's all there at a glance.
    Enhance your gaming experience with just one button
    Get perfect viewing for games with just one touch of a button. Game Mode adjusts your monitor's settings instantly to give you an optimised gaming experience. Game Mode smartly detects the changes in scenes, enhances the colour and alters the screen's contrast to make dark spots darker and light spots lighter so you can see all the action at all times. There is less lag thanks to a faster video response time that ensures that the picture keeps up with action and won't let you down.
    Versatile connectivity for all your UHD-compatible devices
    Your Samsung UHD monitor is perfect for your game consoles as well as your PC. Thanks to 2 HDMI ports, both your computer and your console can be connected simultaneously, so you don't have to unplug and plug in each time when you want to switch between them. That means less hassle and more time for entertainment. Thanks to DisplayPort connectivity, your monitor is also ready to connect to UHD-compatible devices and content.
    *Supports HDMI 1.4 (3840 x 2160, 30Hz) and Display Port 1.2 (3840 x 2160, 60Hz)
    Screen Size 70.8cm (28")
    Panel Type TN
    Brightness 370cd/m²
    Contrast Ratio 1000:1 (Typ)
    Dynamic Contrast Ratio Mega ∞
    Resolution 3840 x 2160
    Response Time 1ms (GTG)
    Color Supported
    Viewing Angle
    1B
    (H / V ): 170 ° / 160 °
    Embedded Function Eco Saving, Samsung MagicAngle, Samsung MagicBright3, Off Timer, Image Size, UHD Upscale, PIP 2.0, PBP
    Additional PC S/W Easy Setting Box
    OS Compatibility Windows, Mac
    Windows Certification Windows 8.1
    D-Sub No
    DVI No
    Dual Link DVI No
    Display Port 1
    HDMI 2
    USB No
    Headphone 1
    USB Hub No
    Power Supply AC100-240V (50/60Hz)
    Power Consumption 32W (Energy Star current test condition)
    Power Consumption (Stand-by) 0.3W (Typ)
    Type External Adaptor
    Set Dimension with Stand (WxHxD) 660.9 x 486.3 x 169.4mm
    Set Dimension without Stand (WxHxD) 660.9 x 410.0 x 64.7mm
    Package Dimension (WxHxD) 794.0 x 452.0 x 109.0mm
    Set Weight with Stand 5.65Kg
    Set weight without stand 5.05Kg
    Package Weight 7.40Kg
    Reviews
    http://forums.overclockers.co.uk/sho...php?t=18590127
    http://hardforum.com/showthread.php?t=1811968
    http://www.overclock.net/t/1472671/s...-has-begun/470
    En usa los están vendiendo a $ 600 en menos de 2 horas el stock paso de 17 a 13 parece que hay interés por este monitor, ya lei que un usuario a puesto a la venta su U3011 y un reciente poseedor del Dell UP2414Q tiene pensado cambiarlo también dado que este no debe hacer los 60Hz por MST
    http://www.ncixus.com/products/index.php?sku=95635
    Ya esta disponible la reserva en alternate € 689
    http://www.alternate.es/Samsung/U28D...roduct/1130804
    Ya esta disponible Ebay España € 549
    http://www.ebay.es/itm/Samsung-U28D5...item19e94157f8
    Última edición por Patagonico; 09/04/2014 a las 23:22
    Asus X99 Strix Gaming - I7 5960X 4.2 ghz
    Thermaltake Core V71 - Fuente Thermaltake Smart M1200W - 85A
    Cooler Micro Nxzt Kraken X42
    Memoria 32 GB Corsair Vengance Led DDR4 3200
    GPU Zotac RTX 2080 Ti AMP! - Monitor Acer Predator XB273K 4K 144hz
    Con domicilio en Noticias3d.com Avatar de agur
    Sto.Domingo de los Tsáchilas -Ecuador
    Predeterminado Re: Samsung u28d590d
    me gusta hasta que leo TN. pero como 4k de entrada es genial.
    CPU: 2x Xeon X5650 (ES) @ 4.0 Ghzs /Motherboard: EVGA CLASSIFIED SR2/RAM: 24 Gb ddr3 1800 24 threads of pure POWWARRRR
    GPU: CrossfireX 2x Gigabyte HD 7970 OC + nv GTX 470 for Physx /HDD:2x SIIG INC SC-SA0T11-S1 (sata6 @ PCIe 2x) /killer xeno pro 128MB DDR
    / Corsair H100+H80i
    / Windows 10 pro 64bit
    Cita Iniciado por agur Ver mensaje
    Si yo pensaba lo mismo pero lo que lei en 3 o 4 sitios donde probaron este monitor no lo ponen como un problema aparentemente no es el conocido panel TN sino algo de mejor calidad, el usuario de esta review es el que prefiere para jugar de sus 3 monitores, me parece que abra que estar atento cuando se publiquen mas reviews.-
    I have a Dell U2713HM, as well as a Asus VG278H and I always went back to the Asus for gaming, purely because of the gaming experience between the 2. The Dell IPS had the better colours and the IQ was better but the IPS never felt smooth and tearing was evident. Putting Vsync on, invoked input lag, so it was a trade off with either tearing or input lag and for fast shooters, I chose the tearing. With the Samsung, I have noticed how smooth it is. I don't get the same tearing (maybe because frames are lower) or the input lag. Not sure if this is because of being a TN panel or other reasons but the Samsung 4K is now my monitor of choice for gaming
    Saludos.-
    ya veremos, estaré atento.
    / Corsair H100+H80i
    De a poco ire actualizando las impresiones de los usuarios que lograron conseguir este monitor todas sus impresiones positiva y negativas acabo de actualizar, este forero lo compara con su U3011 y también lo ve bueno.
    Difícilmente lo pueda conseguir en mi país por ser un producto importado y en monitores nadie ofrece Samsung solo TV, yo estoy a la espera del Samsung U8550 (mi vieja tv presenta desperfectos) pero si este monitor es bueno también ire por el si logro conseguirlo.
    Saludos.-
    Última edición por Patagonico; 04/04/2014 a las 10:54
    Cita Iniciado por Patagonico Ver mensaje
    Saludos.-
    donde vives??? yo ahora en ecuador y lo importo todo, prefiero pagar 200$ de aduanas a no tener lo que quiero, cómpralo tu mismo e impórtalo, te saldrá algo mas caro, pero lo tendrás.
    / Corsair H100+H80i
    Argentina, esta prohibida la importación y si consigues algo es una burocracia terrible y te cobran un impuesto del 50% sobre el producto, ayer uno de mis compañeros se paso casi medio día por un producto que importo de China en diciembre antes de la prohibición.
    Devaluación de la moneda, inflación 30 a 40% o sea dinero en mano invierte porque después te saldrá mas caro.
    Saludos.-
    Vive aquí Avatar de matuso
    Alicante
    Estoy esperando este monitor con muchas ganas, he visto que sale a la venta el 14 de abril en UK y USA.
    Cooler Master HAF X Corsair H105 Asus X99-E WS i7 5820k Corsair Vengeance 8x4GB DDR4 3200MHz SSD Samsung 950 pro 512GB EVGA GTX 1080Ti FE Corsair RM1000 Acer Predator X34
    Cita Iniciado por matuso Ver mensaje
    Hay 4 cosas que veo interesante
    Panel de 10 bits
    upscaling
    tiempo de respuesta 1ms
    Panel TN pero de calidad
    En ebay España esta publicado a 549 Euros envio gratis no se si tiene algún costo adicional
    Saludos.-
    en cuanto pueda lo compro. igual tardo un par de meses, pero creo que lo probaré.
    / Corsair H100+H80i
