Resultados 1 al 2 de 2
Tema: Error al abrir Eclipse
    Predeterminado Error al abrir Eclipse
    Hola. Me ocurre un error al abrir Eclipse. Este es el archivo .log que Eclipse hizo. Me pueden ayudar?
    Código:
    !SESSION 2020-12-05 12:53:04.332 -----------------------------------------------eclipse.buildId=M20130204-1200
    java.version=15.0.1
    java.vendor=Oracle Corporation
    BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=es_AR
    Framework arguments:  -product org.eclipse.epp.package.java.product
    Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
    !ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2020-12-05 12:53:05.925
    !MESSAGE FrameworkEvent ERROR
    !STACK 0
    org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612 [1]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
        at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
        at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
        at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
    !ENTRY org.eclipse.osgi 4 0 2020-12-05 12:53:05.935
    !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612.jar was not resolved.
    !ENTRY org.eclipse.osgi 2 0 2020-12-05 12:53:05.957
    !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
    !SUBENTRY 1 org.eclipse.osgi 2 0 2020-12-05 12:53:05.957
    !SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2020-12-05 12:53:05.957
    !MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.1))(&(osgi.ee=JavaSE)(version=1.4)))".
    !ENTRY org.eclipse.osgi 2 0 2020-12-05 12:53:05.960
    !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
    !SUBENTRY 1 org.eclipse.osgi 2 0 2020-12-05 12:53:05.960
    !MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612 [1] was not resolved.
    !SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2020-12-05 12:53:05.960
    !ENTRY org.eclipse.osgi 4 0 2020-12-05 12:53:05.962
    !MESSAGE Application error
    !STACK 1
    java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
        at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.base/java.lang.reflect.Method.invoke(Method.java:564)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
        at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
        at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
    Predeterminado Re: Error al abrir Eclipse
    Puedes poner tu config.ini?
